timing chain tension can it be done with out the special tools
For a BMW 740iL, BMW require you to use a special tool to adjust the tension on the timing chain for a M62 series 740iL V-8 5.75liter engine dated 08-1998?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Looks to me that all you need is 19mm deep socket. Check out what the expert at http://forums.bimmerforums.com/forum/sho... show you and see if that is the information you need. Good Luck....
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 1,354
