メインコンテンツにスキップ
Appleの2016年ラップトップラインアップの最新モデルは、プロフェッショナルユーザーを対象としています。 15インチ、2880 x 1800 Retinaディスプレイ、クアッドコアIntel Core i7、256 GB / 512 GB / 1 TB / 2TBストレージオプション、16 GB RAM、およびTouch Barを搭載したキーボードです。
260回答 すべてを表示
Water damaged touch bar playing up
Okay so i got my lovely macbook damaged by the rain the other week, and took it to a repair shop who said that it wouldn't even turn on and is 'uneconomical' to repair. However when i got back i put it near a heater for a few hours and now everything on it works fine (apart from a little bit of screen damage but thats livable), the only thing that doesn't work is the touch bar, i cannot use it and more importantly, it randomly selects buttons by itself every 20 seconds or so. Is there any way to disable or relace the touchbar? what would happen if i just cut the cord?
thanks for your time
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
4件の回答
hey James.
As it turns our, the touchbar is essentially impossible to replace by itself as it's glued to the top case.
The only way to truly repair the computer is to have apple send it out for repair which I think is like 1600 bucks... :(
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
it could be a connector? did you ever get this fixed and find out what happened? having the same issues.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Hello
The laptop ended up dying from the water damage so never got the chance to cut the cable and see what would happen
good luck!!
さんによる
@james.harwood5 gotcha thx
さんによる
コメントを追加
nothing should happen if you cut the cord. but if you invest in a top cover witch holds your keyboard and touchpad it has a lot of scews and needs to be put perfect and mind the fact it has to be identical to the apple mac book for this to work. just requires alot of attention and detailed take apart and reassembled. if you havent took one apart dont advise you do it. might just be worth adding a usb mouse and keyboard for the cheapest method in a fix. is all i could say. hope this works for you.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hey did you get the solution to this? My touch bar on my ipad has some water too, and it randomly starts playing around with the controls.
Let me know what you did and if that helped!
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hello. No it stopped turning on before i had the chance to cut the cord. It is upto you what you do, but looking back i wish i just sold it and cut my losses.
Good luck!
さんによる
コメントを追加
回答を追加する
james.harwood5 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 9
今までの合計 1,187
