メインコンテンツにスキップ
Burning rubbery smell, smoke but still works. Can I fix it?
Hi,
I just recieved a kenwood fpm250 from my grandmother, she doesn't have a receipt but it still works. But after 20-30seconds you have a rubbery smell and then smoke. I turned it of, and now want to see iff i can fix it, kenwood refuses to fix it. Eventhough the machine is only 1 year old.
Can someone give me clue how to fix it?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Chantal van Laere , If at all possible find the receipt, if bought on credit card there may be a history of purchase. Some things that could cause the smell, is a bad switch or connection arcing/melting, belt slipping on drive(if equipped),failing capacitor of overheated resistor, perhaps main PCB. The food processor/blender will have to come apart to see what components,etc. may be failing and to see exactly what is going on(link below is not your exact model but may give an idea of how to disassemble to view components).. If you google Kenwood fpm250 burning rubber smell you will see that a lot of people had this issue. Also find your user manual link below. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.youtube.com/watch?v=5-lEDWuH...
http://www.kenwoodworld.com/Global/Instr...
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Chantal van Laere さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 31
今までの合計 7,826
