メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Nikon N80 (F80 としても知られる) は、35mm 一眼レフカメラです。 2000 年 1 月に発売され、モデル番号 1776 で識別されます。
Is it a brick?
Hello!
I just bought a used Nikon N80. It seemed to be in perfect condition, but I took it home and discovered a focusing problem.
The image in the view finder is dim. And when I try to focus, the lens goes in all the way and back out to infinity without finding a focus point.
I tried a few lenses with the same result.
I checked the sensor at the bottom of the chamber, and it's clean.
Like I said, the camera seems to be in great condition otherwise.
What do you think? Is this a brick, or can I fix it?
I should also mention that I bought the camera with the lens improperly attached. I had to carefully cut a tiny piece of plastic off the lens mount to get it off.
Fortunately I paid only $20 for it, plus new batteries.
Thanks for any input on this!
Eric
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Eric Zulaski I wonder if you have trouble with the AF unit or if an adjustment would work. Since you are only in for $20 it maybe worth your while to get the repair manual from this page (under "Document") and go through the adjustment routines etc.
このアンサーは役に立ちましたか?
スコア 3
3 件のコメント:
Thanks for the tip. I will certainly give it a try.
さんによる 共有
I had been on the guide page, but I didn't notice the repair manual tucked in there.
さんによる 共有
It's a present added after you asked the question
さんによる 共有
コメントを追加
回答を追加する
Eric Zulaski さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 28
今までの合計 629
