メインコンテンツにスキップ
250GB HDDとWi-Fiを内蔵したXbox 360のスリム版も出る。修理には複雑なこじ開け作業と特殊な工具が必要です。
306回答 すべてを表示
Red dot blinks 11-12 times
My Xbox 360 slim will not boot up after turning it on on the green button turns red and blinks about 11-12 times with a loud fan noise then shuts back off. I have looked everywhere for a fix for this and have found nothing except people with the same problem. This video is exactly what mine does and there have been no fixes for it yet. https://www.youtube.com/watch?v=yMwajymV...
I have no warranty and already taken it apart to clean it but it really did nothing. Does anyone know how to fix this? I would be super greatful for a solution.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
2件の回答
最も参考になった回答
I got the same problem. The overheating is the issue. I replaced a few bad resistors from the link below and it worked for me.
https://www.youtube.com/watch?v=bNEsEkrn...
GL,
Kevin Tran
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
Mine makes the sound but without the fan or the lights coming on. I tap the power button and nothing happens
さんによる
This definitely works for the blinking red dot failure. However, whoever tries to do this fix, know that you are getting into a really REALLY precise soldering work. You'll need a fine tip for your soldering iron, a really good set of eyes or a big magnifying glass/bench mircoscope, and a very steady hand.
Thank you for pointing into the right direction, Kevin!
さんによる
コメントを追加
I have an Xbox 360 s with the Kinect. 1439 is the model. I had this same exact issue except our light blinked about 30 times while the fans ran fast. I checked all of our resistors and 1 of them resistor 407 had about 100 ohms. I added a drop of solder to jump it and checked it with a meter again and it said 0 ohms. So I plugged it in and she is all backup and running.
The video posted above helped out a lot.
Hope this helps you out.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Shian Lawson さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 26
過去 30 日: 84
今までの合計 16,521
