Why does my game suddenly lag?
why does my game suddenly lag?
この質問は役に立ちましたか?
I depends on the game. If you are playing Minecraft at 720p on low settings, you might have an issue. But if you are running something like Crysis 3 at high and/or ultra settings at 1080p, it is probably too much for your CPU and/or GPU.
このアンサーは役に立ちましたか?
I was playing Gta 5, nba 2k17, and wwe 2k17 at first it was running smooth but suddenly lag then after few weeks it runs smoothly again and same thing happens
Try turning the settings down a bit. Things such as MSAA x and anti-aliasing can affect your performance. It may also be thermal throttling. If the fan ramps up and it gets hot, that may be what it is. If that is the case, try a laptop cooling pad. Hope that helps!
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 278
2 件のコメント
Is, it every game? or just the one
Aaron Bouchard さんによる
What game lags? Are you in some crazy or intense scene when it happens? or is it all the time
Cameron さんによる
