lost button on side, is it repairable?
The little button on the side of my charge has fallen off so I can't access the time, steps etc. Is this repairable
この質問は役に立ちましたか?
この質問は役に立ちましたか?
freakyc, Replacemnt vid. link and possible replacement part below. You can also contact fitbit especially if under warranty or not, as a lot of people have had the same fault and they may value you as a customer and make things right(fit bit support last link). Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.ebay.com/itm/2x-Fitbit-Charge...
このアンサーは役に立ちましたか?
The device is out of warranty I assume, but there are replacement guides online. However, I was unable to find a replacement part. Sorry I couldn't help more. Good luck!
このアンサーは役に立ちましたか?
What replacement guide? Maybe a link will help
Here you go: www.youtube.com/watch?v=udpcDpAqPQU. It isn't the best guide but it works...
過去 24時間: 0
過去 7 日: 2
過去 30 日: 12
今までの合計 1,388
