メインコンテンツにスキップ
3D mechanical puzzle invented in 1974
A middle piece mechanism is loose. What do I do?
The middle piece of the blue side of my Rubik's Cube is unusually loose (but still attached), meaning the blue side turns far more easily than the other sides and, if I try to solve the Cube at my preferred speed (fast enough to solve in 1 minute), it's unusually easy for a piece to pop out.
Taking off the edge and corner pieces reveals that, unlike the stable center pieces, the center of the blue side can be tilted side to side and pulled maybe a few millimeters away from its normal position.
My Rubik's Cube is still usable, but I prefer not to until the blue center piece is secure again. (I'm aware of how to remove corner and edge pieces and put them back on. However, this problem is with the mechanism itself. Again, not fully detached, but uncomfortably loose.)
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
Oh, there's screws in there. Should be easy peazy
https://ruwix.com/the-rubiks-cube/how-ta...
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
There is no screw in my cube
さんによる
コメントを追加
回答を追加する
Joshua Lewis さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 19
今までの合計 3,791
