メインコンテンツにスキップ
Groove Wireless Headphones GV-BT400 HA4 0EJ
4回答 すべてを表示
Why are my wireless headphones not charging?
I have G-Cord AYM T004 and they are flashing red and blue slowly, which I think means it needs to charge, but I had them charging overnight and their normal charging time is 3 hours, they just aren't charging.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 7
8 件のコメント
mine just remains red for a few minutes and off after that...no blue either....cannot use it.....purchased in December 2019
さんによる
I bought this boat air dopes 171 and it's been only a week... this morning when I kept it on charging nor do it shows green light nor red.... otherwise it has to show kind of yellow light.... please help me....
さんによる
Mine just kept it blue while insert in case not blinking up red and than no light. than no connectivity message and not charging up
さんによる
My earphones won’t even turn on I have had them charging for a good hour now
さんによる
Freshavocado I plug mine in to charge and my button won t even turn red it doesn't turn any color and I just got them a week ago but even when I first opened them up to charge them the red light wouldn't turn on I've had them charging for more than 3 hours
さんによる
3件以上のコメントを表示
コメントを追加
6件の回答
ベストアンサー
Wearing your wireless headphones while charging, especially when in motion, can cause damage to the charging port. Check to see if the central five pin chip inside of the micro USB charging port on your headphones is loose. Use something plastic like a plastic fork tine to see if it wiggles inside of the charging port. If it is in fact loose in there, you can stuff a very small piece of paper, about 1/4 inch by 1/8 inch and then folded hot dog way, under the five pin chip to push it up, and when you plug it in *carefully* and use a little force to get it all the way in, it should be able to make the connection to the five connection points on your micro USB charging cable tip. Cheers to cheap fixes. I just did this to my headphones and they are currently charging away. Good luck.
このアンサーは役に立ちましたか?
スコア 10
5 件のコメント:
This is why I love the internet. IT WORKED! God bless you and thanks!!!
さんによる
YES!!! Ty!!! It’s charging!!!!
さんによる
nvm I just needed to take the paper out
さんによる
OMG it's charging!! Thank you!! Mine is a new (cheap) bluetooth earphone, just charge it one time. The second time it wont charge
*I loose the warranty paper so I can not return it or get a repairing servis for free, and the cost of repairing is like buying a new one. Thanks again
さんによる
Hi read your comment low and behold it worked happy old man now Thanks a Million
さんによる
コメントを追加
Drastar Striker, Very little info. to be found on G-Cord AYM T004 head phones. If under warranty return for repair/replacement/refund. The battery/cable/charger or charge port may be faulty damaged. Look in the charge port and blow/pick out(carefully) any dust/debri that may be causing an issue also look in the port for any damage or if it is loose. Try a different compatible charger/cord to see if that is the issue. If different compatible charger/cord does not fix and port looks/test good, the battery or connection could be bad, if able to clean battery connections and reconnect/install battery, still not charging battery probably faulty. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
このアンサーは役に立ちましたか?
スコア 4
1件のコメント:
I had been using boat air dopes 171 for a while now but a few days ago the charging case flased only the green led constant without any blink no matter i charge the airdopes in it or not, and its not working so no charge on my dopes
さんによる
コメントを追加
gullbladder poopy gallalala
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I have a pair of kygo A11 800 headphones and they won't charge, the light that flashes to tell you they are charging doesn't appear. So I was just wondering if anyone has some advice for me.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hi, did you ever get a solution to this? Presently going through the same dilemma
さんによる
コメントを追加
I have a pair of Sumee D-422 headphones that won’t charge. The light that comes on to tell you they’re charging just doesn’t come on. I tried to switch cables and blocks, and I can’t do a hard reset because the power button is a sliding button.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have a pair of fresh n rebel Wireless headphones. Two days ago, it wouldn't even switch on, so naturally I assumed that it was low on battery so I put it to charge. Once I put it to charge however, I see the usual red light that shows that it charges wouldn't switch on- which means it wasn't charging. Somit won't switch on nor will it charge. Help.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Drastar Striker さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 24
過去 30 日: 89
今までの合計 71,937
