メインコンテンツにスキップ
The Summer Infant 3D Lite is a stroller that features an ultra-lightweight design and easy storage capabilities.
8回答 すべてを表示
Replacing the foam grip on handle
My dog chewed off the foam handle. How can I find and replace it?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
選択されたソリューション
steph24w , Did a search for replace foam grip for your stroller and had no luck. I had similar issue with my lawn mower handle where the foam grip had deteriorated. To repair it I went to the hardware store and bought a 6 foot length of foam pipe insulation $1.50, cut it to size to fit my handle(it already has a open seam) so I slid it on and then wrapped the foam with electrical tape to keep in place and reduced the size a bit for comfort. You could do both sides to match. The foam can also be bought as a tape roll also. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
steph24w さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 11
過去 30 日: 22
今までの合計 1,472
