メインコンテンツにスキップ
sylvania 32 watt octron 4100k
I have overhead kitchen lighting that takes 4 -1 inch by 4 foot of these bulbs. I replaced the bulbs but the lights won't turn back in. Breakers are all good. Any idea why they won't work ? The last bulb burnt out and was working. I replaced all 4 and they won't turn on. Help
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
@mizart2u if you can let us know what model your light is and post some images of the light as well as the description marked on the old and new bulbs. Use this guide to add images iFixitでの質問に画像を追加する方法
さんによる
コメントを追加
1 件の回答
選択されたソリューション
@mizart2u , Steve W, ensure you installed the correct bulbs for the fixture if indeed T8 fixture, T8 bulbs should be used. Make sure the bulbs had no protective end covers/plastic on them and are inserted properly. Check for power at the fixture with DVOM or non contact electrical tester, if no power switch or breaker could be bad. If you have power, correct bulbs and properly installed, either there is a bad connection to/from ballast or ballast is bad. Links below may help. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.homerepairtutor.com/fix-your...
http://ask-the-electrician.com/fluoresce...
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Steve W さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 600
