メインコンテンツにスキップ
Also sold under the GMC Sierra and VIA Vtrux names, available in the US, Canada, Mexico and other countries around the world.
81回答 すべてを表示
04 chevy Silverado 4x4: T/C knocking sound not real loud but loud
.. does anyone know what could possibly be making my T/C making a popping noise . I just changed the bearing in it and it's not leaking and just checked my u joints . My chain wasn't lose lose but had just a tad bit of slack . Help please
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
@mrsdye2313 ,Kelsey, Best to have a good local lock smith come and take a look. They are familiar with the GM ignition issue's and may save some time and money by not replacing parts, they can match the up the tumblers in the cylinder. Link below will show how to remove the switch. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
UP DATE 04/20/2017
Kelsey you must have changed your question after I had answered the ignition problem you were having, you really should have posted as a new question. Now you say you TC making noise, best to have a good local transmission shop have a look, these noises in the drive train can emit from different locations could be from rear end/drive shafts/transmission/TC/etc., a trained ear can probably locate and give you diagnoses. Good luck.
https://www.youtube.com/watch?v=ZsyTtFLh...
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
Kelsey Dye さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 232
