I can't put my battery in correctly
My phone froze after a update so I removed the battery and put it back in and now one of the sides are crooked and I can't put it back
hello, you could tap it into place with a hammer, it worked for me after i found a samsung S4 on the side of the road when i was walking one day
sadly though the back case was missing
このアンサーは役に立ちましたか?
The bottom side of the battery is sticking out though
Tap it with a hammer! Do you want it to explode!
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 58
And it won't turn on
minecraft killer55 さんによる
What do you mean? Add some pictures to the question.
George A. さんによる
Hi ,
Did you put it back in the correct way?
Samsung Galaxy S5のバッテリーの交換
Also not sure when you say "....put it back in and now one of the sides are crooked and I can't put it back"
You "put it back in and now you can't put it back" doesn't make sense
jayeff さんによる
Hi,
Does the battery look 'swollen'?
Did you have any problems removing it from the phone?
You might have to compare it to a new compatible battery to see if it is distorted in any way.
jayeff さんによる
