メインコンテンツにスキップ
2015年4月にHuaweiより発売されたAndroidスマートフォンです。
30回答 すべてを表示
Can I fix a broken screen at home?
I have broken the screen of my Huawei P8, quite harshly... Is it possible to fix this myself(at a low cost) instead of sending it to a professional repairplace? If not, do you know where I can go to fix this? And how much it will cost me?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
Hi Inga,
It's work, it would feel challenging to a first timer - but it's not something you should shy away from if you feel up to the task. The monetary savings can only be compared to what your local repair shop would charge you.
Here are some things to consider, an electronics tool kit such as the one sold by ifixit is very helpful, and at a minimum, a screwdriver kit and some kind of prying tool is needed. This guide below is for the P8 Lite, but it will give you a good idea of the work involved to take it apart:
Huawei P8 Lite Teardown
ifixit also sells the screen replacement you need at $55+shipping:
Huawei P8 LCD and Digitizer
If you have absolutely no tools, it might be cheaper or close to same cost to pay for repair service locally. However, the toolkit is forever, and so is the experience.
I hope this helps to give you a general idea of what it entails
Huawei P8 LCD and Digitizerの画像
製品
$9.99
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Inga Katrine Vold さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 1,283
