How to fix the cable rewinder
Hello,
The cable does not rewind completely when i press the botton. I would like to know how to fix this.
Thank you
この質問は役に立ちましたか?
Hello,
Thank you
この質問は役に立ちましたか?
@den23 , Den, Rewind spring may of detached from it's retainer. Use the link below(Philips Marathon Vacuum FC9202) service manual, to aid in disassembly of your vacuum to check/replace/repair the auto rewind spring/mechanism. Pg. 6 show's the mechanism in detail. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 12
過去 30 日: 25
今までの合計 2,857
