メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
A personal computer that resides in one location with its core components inside a case separate to third-party peripherals required for operation, such as a mouse, keyboard, and monitor.
How to repair dead lan port?
how can i fix dead lan port in my desktop? i just try to install a video card after that lan port its not working....
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
4 件のコメント
Did you install the video card while the power supply was plugged in and not switched off behind power supply?
If that's the case then it's not really fixable.
さんによる
Is ther a way to fix it?
さんによる
I install the graphic card then may lan port didn't work already it can't access the network. How can I fix this?
さんによる
@ryan ragojos
What computer make and model and motherboard are you using?
What graphics card?
What LAN adapter - on board or on an adapter card?
What Operating System?
With out this information we can't help you.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Is the LAN port on the motherboard or an adapter? If it is an adapter, try reseating in, make sure it fits securely and level with the motherboard. You can try pinging the adapter in a command prompt with "Ping 127.0.0.1" if you get a time out then the adapter is probably bad.
You can try updating the drivers, you will have to download the drivers from the manufacturer on another computer to a USB drive.
If it the LAN port is on the motherboard, check the BIOS settings for the Ethernet adapter. If the LAN port is on an adapter, then try deleting the network device in Device Manager, remove the driver and then scan for hardware changes.
If none of these steps work, you may be able to get another Ethernet adapter. Check to see if you have an open slot, determine what kind of adapter slot it is (usually it will be PCI). Ethernet adapters are fairly cheap.
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
回答を追加する
mark mendoza さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 23
過去 30 日: 60
今までの合計 31,464
