メインコンテンツにスキップ
モデル番号A1502/2.6GHz(Turbo Boost使用時最大3.1GHz)もしくは2.8GHzTurbo Boost使用時最大3.3GHz)デュアルコアIntel Core i7、4MB共有L3キャッシュに変更可能
494回答 すべてを表示
First WIFI started crashing, now keyboard and trackpad followed! Help
Hello ifixit i need your help. I am travelling in souteast asia with my macbook pro (MacBook Pro "Core i5" 2.6 13" Mid-2014). First i started having issues where after heavy use or while using it for a while the wifi would get jumpy before crashing all together and the macbook would become unresponsive, needing to restart it to get it to work again. After this happening for a while i made a clean reinstall of OS el capitan. I thought this solved the problem but after a while the WIFI started crashing again.
After driving all day i noticed when i took my macbook out of the car, it was so hot from sitting in the hot car all day plus i felt like it might have turned on while in its sleeve. After trying to turn it on the keyboard and trackpad doesnt respond, when i plug in an external mouse the pointer is jumpy and doesnt respond as normal. After cooling it in a cool room for a day, i turn it on and works for five minutes before the wifi, keyboard and trackpad giving up on me.
I hope you guys can help me? Is it a software issue? Is there parts i can change? The click on the trackpad also stopped working several months ago. Thanks :)
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Symptoms you describe make me think there's some overheating. Might simply be that the air intake and cooling are limited by dust/dirt. Try opening the Mac botton and have a look at the conditions of the inside.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
This sounds like a sensor issue on the main logic board. If I am correct, Apple recommends replacing the board. Basically what happens is a sensor reads a bad value (too hot, low voltage, high voltage, etc..) and lowers the PC to it lowest possible settings to protect the hardware. The result is a machine that cannot be used in the crippled state. This happens a lot with the power adapter.
Since you are traveling you likely cannot find an apple service center. You may end up being force to buy a new machine. Your other option would be to find someone who may service Apple devices but that is rare - Apple does not provide service info to third parties.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thank you, is there anything that i can do other than replacing it, a new logic board is quite expensive, anything you could think of would help. Thank you once again
さんによる
コメントを追加
回答を追加する
pablojohn87 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 91
