メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
The sixth generation of the Mazda Protegé, also known as the Mazda Familia and the Mazda 323. The five-door fastback edition was known as the Familia Astina or the 323F.
Why my car turns on for a few seconds then turn right off
I replace my starter with a new one, on my 94 Mazda protege Lx, Now my car turns on for like 5 seconds then it turns right back off, I push the gas padel while the car is on but it only rev once & turn back off, I'm not sure why it's happening.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
is this a manual or automatic?
さんによる
コメントを追加
1 件の回答
最も参考になった回答
@rivera64545 , Jon, Start then stalling issues, is there security light on, bad sensors TPS, MAP, MAF, IAC, O2, failing knock senor, faulty injectors, dirty throttle body, EGR valve, major vacuum leak, failing fuel pump, bad ignition, bad distributor, plugged catalytic converter, etc.etc.. As a first step have the car scanned for trouble codes as it may identify the exact problem. Some of the auto parts suppliers offer free code reading like Pepboys, Nappa, Advanced auto parts,etc and some of the guys are very knowledgeable and may have seen the issue often and put you on the right track or see if one of your buddies have one to lend. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Jon さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 11
今までの合計 278
