メインコンテンツにスキップ
The Lenovo IdeaPad Yoga 11S is a 2015 2-in-1 convertible laptop with an 11.6” multi-touch display.
24回答 すべてを表示
Why is my keyboard and touch screen not working?
My keyboard isn't working and it's also touch screen and that's not working also. None of the keys work. My screen pad to scroll the arrow is also not working. It's impossible to access my laptop because nothing is working at the moment. Could that be a sensor, or what should I change to fix this? Appreciate all help! Thanks.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
In order for you to get access to you data, try using a USB keyboard and mouse. If the usb peripherals work, you may want to backup your data. Secondly, in order to assess whether the problems are hardware or software related, you may want to try to restore the OS with the restore partition or use a "live" OS like Pupply Linux. If the USB ports don't work as well, then it mostly is a hardware problem and would require you to disassemble the unit (depending on your skill level).
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
In order for you to get access to your data, try using a USB keyboard and mouse. If the usb peripherals work, you may want to backup your data. Secondly, in order to assess whether the problems are hardware or software related, you may want to try to restore the OS with the restore partition or use a "live" OS like Pupply Linux. If the USB ports don't work as well, then it mostly is a hardware problem and would require you to disassemble the unit (depending on your skill level).
さんによる
コメントを追加
回答を追加する
Armando さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 3
今までの合計 2,308
