TV screen faulty stripes
My Sony Bravia suddenly playing green and pink colour. When starting up the screen is green and also has green horizontal lines across screen.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Anwar De Vos this "playing green and pink colour" is usually related to a bad panel. I doubt that this is due to overheating or water damage. Of course you do want to check if this is due to either a connection issues (loose or bad cables) or the source device. Tell us if you pull up a menu, does that look green and /or pink as well. Check all input sources i.e. DVD, HDMI, cable etc. Definitely try different cables as well since there were issues with HDMI ports etc. as well as remove your cable box if you have one and connect something like a DVD player directly to the TV. Also, try to reset the TV to factory default settings. This should work for your set:
1.Turn on the TV
2.Point the remote at the TV, press and hold the up arrow button.
3.While holding the up arrow on the remote, press the power button on the TV.
4.You will see the word reset on the TV screen and the TV will turn off and back on automatically.
5.Allow the TV to turn on completely and the set up screen will appear.
6. Follow the steps to set up the TV.
There is a chance that this could be caused by a bad T-Con board or a bad mainboard. Post some high res images of your boards as well as what the screen displays. with your question. That way we can see what you see. Use this guide for that.
このアンサーは役に立ちましたか?
While the screen shows green and white/pink horizontal bars, it can't show the "reset" on the screen. This procedure does not work. However, by unplugging the power input cable located on the rear side of the screen, on the right, and waiting about 10 seconds then reconnecting it, the TV will reboot and clear the issue.
Hey JD, just got a Sony Bravia and the same line appear as your problem. Yet, I don't understand your solution...can you explain further?
Hello there! I had the same issue with my Sony Bravia Tv and I found a solution on my tv manual. Check your tv coax cable and remove it. If that resolved the issue meaning you need to change coax. If your coax is rated 300 ohm, used 75 ohm instead. So far, i dont get the line anymore! SOLVED
I just got up this morning and turned on the tv and was met with the green and white strip issue. After swearing for a while I unplugged the tv for a minute and the plugged it back in. The tv rebooted and all seems to be fine. Holy this is not a sign the panel is failing.
Yes encountered the green and white stripe across the screen of my Sony Bravia TV. Simply, I disconnected the power source for about 10 seconds, after plugging it back up the TV went through the settings and returned to the previous settings without any issues. I am wondering if it is an indication a possible issue with the TV, it is approximately 2 years old.
このアンサーは役に立ちましたか?
I had this happen twice over the past 2 years. The first time was within 6 months of getting it. It happened again about a year later. I don't think it is an issue with the TV. It could have something to do with the quality of the cable and possibly the amount of resistance they offer. Just my opinion.
It seems that IF the simple 'power' reset options don't fix the Horizontal Lines on the Sony TV - it is probably the LCD Panel. Replacing the 'cards' inside the TV will not fix Horizontal Lines.
Woke up this morning to white and green horizontal lines. Follow the advice to unplug the TV and the TV rebuild. Problem solved.
このアンサーは役に立ちましたか?
Did anyone find out how to fix this?
このアンサーは役に立ちましたか?
i have the same issue as above but disconnecting power and disconnecting coax, does not fix it.
I'm having the same exact issue (green and white screen). It started Aug. 5, 2023. I've had it since 2018. It has been an amazing TV. Up till now.
Bonjour personne à trouvé la solution à ce souci j'ai même souci sûre tv dual 65pouces
このアンサーは役に立ちましたか?
過去 24時間: 5
過去 7 日: 17
過去 30 日: 66
今までの合計 87,820
11 件のコメント
Were you able to fix this issue? I haven't had any issues with my Sony Bravia before and suddenly today, the screen turned to black with vertical lines. Any suggestions for fixing it?
Nicole さんによる
My tv has a problem of displaying only half screen especially twins picture
Malale Haniph さんによる
I haven't had any issues with my Sony Bravia either, until this morning when I turning it on. It only shows White and Green horizontal lines or bars and it splits the pattern down the middle.
J.D. Wismayer さんによる
I having a problem with my Sony tv it only shows White and Green horizontal lines or bars and it splits the pattern down the middle.
jsantiago_81 さんによる
I have the same problem..two years old! Did you find a fix??
Kent さんによる
6件以上のコメントを表示
