メインコンテンツにスキップ
The Dell Vostro 1400 is part of a line of small business oriented laptops. The device includes a 14" screen released in July of 2007.
4回答 すべてを表示
Speakers stopped working after plugging in my headphones.
I plugged my headphones into my laptop and it worked fine but when I removed them the speakers wouldn't play. I tried messing with the audio settings a bit but I still can't get them to work, anyone have any ideas?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Sorry about your troubles, David. Make sure that your speakers are on and that the volume is turned up loud enough. You can check this by looking at the sound or volume setting on the laptop. Also, you can try running a diagnostic test and this will tell you if there is a problem with the hardware. You can do this by pressing "F12" and selecting "diagnostic." If none of these things work you could take it to your local electronic store and make sure the problem isn't with the speakers themselves.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
David Hogg さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 91
