メインコンテンツにスキップ
Released in 2006, identified by model number PP20L for e1505
How to determine SATA controller revision in Windows.
Short and sweet: how do I know how fast the SATA interface will be from windows (10). I'm not talking about the HDD.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
ベストアンサー
@pccheese I'd start with a good benchmark program to get that information. You probably already know that there are two factors that determine the speed: the interface/controller and the device i.e. HDD. Try HWiNFO or SiSoftware Sandra. If you use HWINFO, navigate in the device tree to Bus > PCI Bus #0. Under PCI Bus #0, click on the SATA AHCI Controller device. Details about the controller will dhoe in a pane that you can then scroll through to find a heading "SATA Host Controller" with the Interface Speed Supported
このアンサーは役に立ちましたか?
スコア 4
1件のコメント:
Thanks oldturkey03. I found that it is sata I. The theoretical speed of SATA is about 180 MB/s, but the real speed is around 150. Do you think an SSD will do any good if it's throttled down by the interface?
I've narrowed it down to two:
This crazy fast HDD: https://www.amazon.com/gp/aw/d/B01LYNQXC...
Or my favorite SATA SSD: https://www.amazon.com/gp/aw/d/B01F9G43W...
Thanks again.
さんによる
コメントを追加
回答を追加する
George A. さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 6
今までの合計 1,360
