メインコンテンツにスキップ
モデル番号 A1418 / Late 2012 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7プロセッサ
212回答 すべてを表示
Logic Board Faulty or Damaged?
Hello There... I was wondering if someone can give some clue what is happening in this situation..:
problem: iMac won't turn on...
tests:
1. Removed lcd/glass panel successfully, I notice that NONE diagnostic led was on... so...
I went..:
2. I checked de AC cable, and it gave me the 120V AC from the outlet so we are good...
3. checked inside AC input in the Mac, and also gave me the 120V AC... (good)
4. I plugged in the PSU, and tested some pins with the ground pin... and 3 pins gave me 12V DC. (so I think the PSU is fine)
What else can I try????
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
The PSU may receive power but is not sending further to the board, before going after a logic board damage i would try with a new power supply. Most of the cases when no diagnostic led is on the board doesn't receive power due to a faulty power supply.
このアンサーは役に立ちましたか?
スコア 1
5 件のコメント:
@kaykay another one hits 500
さんによる
even though the PSU pinout gave me 12V DC on 3 pins?... I will try another psu..
さんによる
Always keeping an eye out for me @mayer. Thank you :)
さんによる
Hello there, after all.. I installed a new PSU, the imac start working again... but.. after several hours the iMac was on.. it turned off... so I checked again inside, and I have no leds on... (again)... I have no clue what is happening...
さんによる
@makibuki //have u found problem. i have the same issue
さんによる
コメントを追加
回答を追加する
jbermudez27 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 3
今までの合計 255
