Why is my computer not charging?
My computer is working fine but it's showing that is not charging and the computer is still on, but if i unplug the charger the computer shuts down. I don't know what is going on???
この質問は役に立ちましたか?
この質問は役に立ちましたか?
First, I would recommend checking if the outlet that you are using is working. Maybe try a different outlet. If that doesn't work I would recommend trying a different charger or charging cable. That might work. If it doesn't, then you may want to consider replacing your battery.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 225
