メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2014年にSonyから発売されたワイヤレスヘッドホンです。
How do you fix the broken swivel part on them?
I got them this last Christmas and I broke them around 2 months ago when my mom told me my dad had a cancerous brain tumor. I dropped them on the hospital ground when she told me and the swivel part broke. The chord is still attatched and they still work but the one side hangs by the chord inside the headphones.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 16
7 件のコメント
Hello,
I’m also looking for this part.I contacted Sony France, and some parts distributors. For now, I haven’t good news to share and I’m still waiting.
I saw on Amazon lot of people who have the same issue as us.
I wonder if the parts of XB950BT and XB950B1 are compatible with each other. Do you know guys ?
Thank you for the topic and your possible answers.
Cheers
さんによる
my swivel part broke on my XB950B1
さんによる
I have the same problem except I’ve got no clue how exactly it happened. I used them, I put them away, I came back and it was broken
さんによる
same here - almost 200 spent and cant even fix
さんによる
This seems like a normal issue (https://ap.community.sony.com/s/question...). Same issue with literally every Sony device that has a hinge. Including the XM4 Sony won't budge. Just poor, poor design. Never buying from them again. Seriously.
さんによる
2件以上のコメントを表示
コメントを追加
22件の回答
最も参考になった回答
All that pressure on such a tiny plastic part - for shame, Sony, for shame. What a terrible design.
I bought a replacement swivel part on eBay but once I disassembled the headphones it was clear that unless you cut and splice that wire, and who knows how many tiny little wires it contains, it is for all intents and purposes impossible to remove the broken part and install the new part. That’s when I stumbled across this page.
I fixed my headphones by holding the broken side headphones in an aligned, “neutral” position, and by then drilling two tiny holes through the opposing swiveling parts. It was not too hard to maneuver a small hand drill with a very small 1/16” bit coming at the parts from the earphone side. The holes were drilled parallel to the direction of the headband. I then sanded all the faces with a bit of 100 grit sandpaper, slathered 5-minute epoxy on the faces, and ran a few simple stitches through the holes and the walls of the swiveling parts, and pulled/tied them as tightly as I could, drawing the sanded faces together into the epoxy. Space is tight in there so I used a small curved upholsterer’s needle, a pair of pliers to pull the needle through, and some very strong V-92 sailmaker’s thread that I happened to have lying around. (It’s similar to upholstery thread; not particularly thick but quite strong.)
The epoxy cured quickly as I did this and the stitches provide a little bit of extra structural support fairly near the outer edge of what had been the swiveling parts, so, they’re in a place where they can minimize any twisting effect of the headphones on the repair. On reassembly the faceplate completely covers the stitches, and even though the threads are sticking out a bit they don’t misalign the faceplate at all. Except for the loss of the swiveling function, the repair is invisible except for a thin line of epoxy on the inside of the band.
このアンサーは役に立ちましたか?
スコア 6
2 件のコメント:
Great minds think alike
さんによる
See Jaz syed's fix below - same idea but better! Cannibalizing two screws to hold the broken pieces together is brilliant.
さんによる
コメントを追加
Hi guys I have this problem, if you undo the screws, remove the metal plate and snapped off piece and then cut away on the other end of the snapped piece (thays still attatched to the headphones) untill it's pretty much flush then scuff each surface you can just super glue the ear piece back onto the band, it's the only solution I can find, I'll update you if it doesn't work but it looks alright just means you lose the pivot function, but with the big squashy earpads I think the fit shouldn't be effected as long as you superglue it flat! (Once you do this though there's no going back
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
I opened the area up where the swivel piece is located and super glued it. I worked all of 2 hours before my son dropped the headphones and the broke again. The part I need is specific to ordering it...Really simple to repair, I just need the part. You might be able to go here to order the part. I'll check tomorrow to see and provide my results here.
https://esupport.sony.com/US/p/model-acc...
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
is there a place where i can purchase the swivel part for the mdr-xb650bt model??
さんによる
コメントを追加
Good fix Jaz. This isn’t a spam link - it shows very clearly how to drill through the two broken pieces with a 1.5mm bit (I think a 1/16” bit would work in the US) and use two of the casing screws to hold the broken pieces together. No glue, thread, or soldering.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Hi. Mine did not break at swivel. It actually cracked between exterior screws where the model number is displayed as if screws were fastened too tightly. I purchased a new bracket to replace left and only outside bracket that holds the earpiece. Will I have problems removing old and simply basically screwing on new bracket onto earpiece and in tact swivel? I mean this is the latest model and I notice plastic thin covers on the inside of each side of each "fork" that holds ear piece. Please tell me it's an easy fix....
さんによる
コメントを追加
It's not that simple to repair the hinge, as soon as you remove the screws you'll see that the wire is direct connected to it with no option to disconnect unless you disassemble it all
このアンサーは役に立ちましたか?
スコア 1
5 件のコメント:
the wire threads through, is not direct connected, but yes you would have to take the earpiece apart to remove the wire and rethread it through if your could replace that one plastic part of the headband where the swivel is attached. Clearly this is a design defect (intentional - after ~70 years in the electronics business of course they know it's going to break there); as all the stresses upon the ear cup/headband connection is focused on a cylindrical area, narrowed from ~7 mm to 3-5mm wide, with a 1mm thick plastic wall. This obviously should be made of metal. I can only conclude that they intended it to break.
さんによる
I should say that the wire is direct connected to components in each earcup on both ends. Makes repair more complicated, where a better design would have made repair completely unnecessary.
さんによる
Yes. I got the part from ecopart,. After I received it, the other side broke. I had to essentially remove all connections from the motherboards, disassemble (a real pita) resolder connections. After all that, my left channel has no sound now. I have procured a new motherboard from ecopart, and a new headband with wires, but it is so needlessly complex (should have plug in connectors, and don't let me get started about the crap design of the swivel) I am not sure I want to invest another 2 hours trying to do it. Not to mention that the motherboard is visibly different, (different revision?) and I am not sure that it will work if I am lucky enough to do it right.
さんによる
I have a pretty good idea for reverse-engineering a better swivel, but I am not sure I would want to take on the task of disassembling and reassembling with the soldering the units for people who wanted to pay for it. I am confident it would work though.
さんによる
My 11yr old has this same issue. It’s now 2019 and it still going on, sad. He’s had and broken umpteen different headphones but as a twitch gamer these are by far his favorite, even over the more expensive ones. So dad the tinkerer and locomotive electrician has been tasked with the repair. Sony does sell the entire headband setup for around $43, google the model # and it’s the first hit. Of course I’m going to TRY to pull a 6million dollar man repair and make them BETTER!! I’m thinking I may try to get on my buddies CNC and machine the part of aluminum or maybe something even stronger. And since so many seem to break I bet I could do ok online selling them with good instructions and needed tooling. The thread and epoxy trick sounds pretty good but I hate to lose the swivel. I will report back!
さんによる
コメントを追加
you can't. what I did to keep them functional is a shotty zip tie job
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Please tell me there was some duct tape used also! They are like peanut butter and jelly, Tom and jerry, fiberglass and resin, tweakers and electronics failed repairs!
さんによる
コメントを追加
Do we have any solutions for a broke college student that doesn’t have any power tools available?
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
Yeah mate just do what me and tpe2 did, there's no need to drill it out just use something to cut the broken plastic piece of and then superglue the earpiece back on (but you do lose the swivel function) I have had mine like this for over a month without any problem, be sure to use plenty of super glue tho and make sure the earpiece is in a neutral position!
さんによる
I ended up doing this, thank you!! I used baking soda as a filler to get a stronger hold.
さんによる
Would you mind sharing what you mean by using baking soda as a filler to get a stronger hold please? I am about to attempt to fix my son’s broken headphones. Thank you
さんによる
Once the superglue is in place, dribble a little baking soda over it. This causes a chemical reaction with the superglue, making it very hard and filling in gaps. (Superglue by itself is terrible at filling gaps.) There are lots of interesting examples on YouTube for this trick.
さんによる
コメントを追加
My daughter handed me her Sony headphones in 3 pieces, both legs of the swivel had broken off - SONY! whatever happened to quality control? Anyway, gluing was out of the question as fragments of plastic were also missing. On Amazon, I bought a pack of 'mouldable glue' by a company called 'Sugru'. The pack contains 8 Saches, each containing a piece of 'putty'. Before opening a pouch, I had to remove the broken legs from the dangling headphone - (carefully remove the earcushion, it has a tacky base which will hold the earcushion again on completion, remove the 4 Philips screws and lift the cover). Pushed the broken legs out easily. Placed one broken leg in position and moulded the putty around the joint. The putty is a silicone rubber and takes 24 hours to cure. Then did the other leg ditto. I'm positively surprised at the result, and still have movement of the earpiece. Thank you Sugru, and I hope this info helps others. Kind regards Kerry.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Kerry would you be able to explain in a bit more detail what's you did? Getting lost with the pushed the leg out and put it into position and used the putty... would love to use your method as you still get the movement
さんによる
コメントを追加
What I did and has held up for at least 6 months now is to tape round the swivel, pushing the two broken parts together and then leaving a gap at the top. Make sure it’s in line and slowly fill it with gorllia glue. No the headphones won’t be able to swivel again on that side but it hasn’t made a difference to their use, the other side swivels and that’s enough.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
画像
Had the same problem. Completely replaced the plastic hinge system. It now has a metal swivel (plus one extra degree of freedom). Would've cost me a quarter of the headphone MRP just to replace the broken swivel. Instead i got this done in 10 INR.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
There is an excellent video on YouTube about the same
Link: https://youtu.be/DVKypArMB30
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I solved this by using a needle & heavy duty thread such as upholstery thread and simply tying the 2 pieces together by feeding it through the hole where the audio wire goes through multiple times, it secured both bits as well as kept a decent amount of swivel in the joint and you can't even see that the headphones were even broken!!! Hope this helps
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
How do I fixy left side siwel portion
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Me too, this has happened to both the first Sony headphones I had and now the second ones I got after the first ones broke. idk why they keep breaking in the exact same way agh,
I cellotape it together when I want to put them on but that’s still not very good because they usually still fall apart again when they’re cellotaped
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Mine just happened! Can I fix it with a glue stick?
Have nothing else
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hello everyone. I broke that %#*@ hinge twice, and repaired it twice. Than a week ago my gf broke BOTH hinges at once. And I gave up.
These earphones’ mechanical design is a total crap. I believe Sony made this poor cheap design intentionally because any amateur on a glance could tell you it’s not going to survive for a long time. Tiny plastic swivel part either wears out to its death in a couple of years just because this Universe invented friction thing, like my 1st time it broke: I walked on the street and suddenly…, or breaks if you just look on these headphones too strictly: 30cm fall for them is deadly dangerous.
How I fixed: I disassembled ear (took off earpad and removed all the screws I see), soldered out two wires of speaker (be accurate, they’re very short). Than I removed all the screws in headrest slide mechanism, fully retracted it and removed. Each ear hinge has a wire inside. To remove it you’ll need to solder out all 7 (or 9, I don’t remember) tiny wires from headphones’ PCB and put away one long elastic cap, and two more tiny ones. Than you’ll need to carefully remove this wire using these holes and some sort of hard but dull pin. After it you’ll have access to the Hinge.
I had this hinge’s head broken. First time I built it up using super glue (cyanoacrylate) with soda: this high-tech is widely covered in Internet. I made some sort of tiny mold out of plasticine and layered it several times with glue-soda-glue-soda. Having enough I let it cure for a while and then processed it with sandpaper and fine file to make a proper form, and finally drilled a hole for a wire in the center of it. Assembled in reverse, soldered. It worked perfectly for a year.
After it broke the second time, I bought spare part on Avito (our eBay clone): https://www.avito.ru/moskva/audio_i_vide... , 1500 RUB (~25 USD w/o delivery) and replaced it instead of repairing, with the same procedure of assembly.
Sorry for my English being far from perfect. I hope I helped someone to fix that osteoporosis guy, finally sell them on eBay and buy some more decent product.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Only way is to superglue them. Or replace the speakers cups and rewire everything. They make them cheap so they break always in that area. Wish they used metal instead of rubber plastic
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
3 ways to fix these awesome sounding headphones !!
1) No glue or soldering iron required : https://youtu.be/DVKypArMB30.
2) soldering iron required : https://youtu.be/PJ1X-CbX29Q.
3) soldering iron and super glue required : https://youtu.be/fnBbyw9bG7k.
Enjoy!!!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
If you want to buy new Headphones or replace it then visit my site Headphone Graph
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I was able to click them in place and use plastic weld to melt the plastic back together
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Sound problem please tell
Update (09/05/23)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Kyle Martins さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 16
過去 30 日: 120
今までの合計 74,313
