メインコンテンツにスキップ
The second iteration of Samsung Galaxy Tab tablet computers with a 7.0-inch screen. Model numbers: GT-P3105, GT-P3100, and GT-P3105.
125回答 すべてを表示
cannot start it even pressing on both buttons and not charging at all
tab 2 was on charge but when trying to start it won't start goes to android film ware but accidentally shut down and from that moment couldn't restart it at all .Please need help to solve this matter ,even please power button and volume up nothing happen
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Prinsley David, Try unplugging the battery for 5 minutes and then retry(1st link below). No go, then try a factory reset if able(doing so will lose all stored data). Reset info. from 2nd link below.
Press and hold the Power button until the Device options screen appears.
Select Power off.
Select OK.
Press and hold the Volume up button then press and hold the Power button.
When the Samsung logo appears, release all.
Select wipe data/factory reset. (Use the Volume buttons to highlight and the Power button to select.)
Select Yes -- delete all user data.
Select reboot system now.
Allow several minutes for the reboot process to complete.
Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Samsung Galaxy Tab 2 7.0 Battery Replacement
https://www.androidpit.com/forum/607041/...
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Prinsley David さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 80
