メインコンテンツにスキップ
ユニボディMacBook Pro 13インチ Unibodyディスプレイモデルは2009年〜2012年に製造販売されました。
4630回答 すべてを表示
How can I identify what year an optical drive is from?
I've been working on macs for about 18 months now, and 1 thing that always frustrates me is replacing the optical drives. I often times can't get a replacement drive to work in a MacBook that I know worked in another MacBook.
I'm told there's a way to identify the optical drive to know exactly what year a1278 or a1286 it will work in, but i'm not sure how to do that.
Does anyone know how to identify that to make it easier to know which optical drives I have in stock will work with which model year MBPs??
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
PowerBook Medic is very good about compatibility listings. Do your search there using the model number of the drive.
このアンサーは役に立ちましたか?
スコア 4
1件のコメント:
thanks for that...
when I look up model UJ868A anywhere, i typically get the answer that they're compatible with all a1278 & a1286 model MacBooks & pros. but i've found that some of these drives work in some models but not others.
is there a better way to look this up or know?
さんによる
コメントを追加
回答を追加する
dollartripclub さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 3
今までの合計 60
