メインコンテンツにスキップ
Motorola released the Droid Turbo 2 in late October 2015. Model number XT1585.
What screwdriver does the inside take?
I have the iPhone screwdriver but that doesn't work
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
that's a pretty vague question.
do you have a picture of what youre talking about?
さんによる
コメントを追加
1 件の回答
最も参考になった回答
@turtlj ,Turtl Johnson, From the partial disassembly link below, these are the screw types mentioned.
17 screws from the board using a T3 bit on your screw driver. Or, use a T4 bit if the screw is slightly stripped.
4 silver screws on the top and bottom are 4.0mm Phillips #00, and the 13 black screws around the sides are 3.0mm Phillips #00.
Using a T3 bit on your screw driver, remove the two 4.0mm screws from the metal bracket.
Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Motorola Droid Turbo 2 Rear-Facing Camera Replacement
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Turtl Johnson さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 12
今までの合計 833
