メインコンテンツにスキップ
2012年11月2日に発売された第四世代のiPadです。16、32、64GBモデルがあります。モデル番号はA1458です。
218回答 すべてを表示
Charger broke off in iPad
My mom has a 4th gerneration iPad, model A1458. It has an electric wall charger with an end similar to the iPhone 6. While her iPad was charging, it fell from her chair to the floor, and the charger that is inserted into the iPad to charge broke in half, leaving half in the iPad with no way to get it out.
Any suggestions?
Thanks!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
I just used tweezers for mine that broke off in it.. took me a few tries, but it came out!
さんによる
コメントを追加
2件の回答
ベストアンサー
The plug does "snap" in place so it will require some light force to remove. Try some tweezers or fine point long-nose pliers. You may also try to pry it out (gently) with something pointy, working one side at a time.
Be careful because you don't want to do any unnecessary damage to the housing, port or glass.
If you don't have the proper tools, consider going to your local shop and they may do it for a low fee.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
This happened to me today. I used a small kitchen paring knife and pried at one end until it loosened and fell out.
さんによる
コメントを追加
I would try and pry it out carefully with pointed tweezers :
https://www.amazon.com/URBEST-Compact-St...
try to keep the tweezers in the center of the port hold when prying the piece out because there are pins on the side wall of the port that can easily be damaged.
There are shops that do this type of thing for free. I do at my shop. I would call around and ask a few different shops.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
thank you for the link... this is so helpful. never had this happen before!
さんによる
コメントを追加
回答を追加する
tshortgobucks さん、ありがとうございました!
統計データ:
過去 24時間: 7
過去 7 日: 20
過去 30 日: 126
今までの合計 18,178
