Where is the oil pressure switch located?
Where is the oil pressure switch located on the motor?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
On the 2000 inline 6 it is down on the block just above the oil filter. Look for a small cylinder with a wire on one end
このアンサーは役に立ちましたか?
On the 3.7L engine it's at the front of the engine above the oil filter, remove filter for better access. Unplug the wiring harness by moving the red safety tab and depressing the lock tab. Requires 1 1/16" deep socket to remove.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 3,929
