メインコンテンツにスキップ
Repair guides and support for the Nikon D800 and D800E digital SLR cameras announced in February 2012.
18回答 すべてを表示
Not able to change out lens. Either camera or lens will not release.
I am not able to change out lenses. The Nikon lens that is currently on the camera will not release. Or the camera will not release the lens. I'm not sure if it's the lens or the camera that is the problem.
Can anyone give me some advice!
Thank you
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
it seems this is a pretty common problem with this series, you might need to send it in.
http://www.sportsshooter.com/message_dis...
try reseating it like you were going to try and put the lens on and twist it into the lock position and then try and unlock it. it might be stuck but if that doesn't work you might need to send it in :(
Sorry!!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hi, I had this problem one day with my 50mm 1.4 af-s. It came from a screw in the back of the lens that was unscrewed. I forced ... I had no choice but it is a very big risk. good luck
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
edington さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 262
