My h/lamps won,t comeon
the headlamps on my 2000 4-runner, due not come on.
high beams an p/lamps all work
fuses are good
rdmattia , check/test both bulbs(totally possible for them both to be blown out), check wires/sockets/plugs for corrosion/damage/loose,dimmer relay, faulty switch(test), More info. at the link below. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 82
