メインコンテンツにスキップ
モデル番号A1502/2.6GHz(Turbo Boost使用時最大3.1GHz)もしくは2.8GHzTurbo Boost使用時最大3.3GHz)デュアルコアIntel Core i7、4MB共有L3キャッシュに変更可能
494回答 すべてを表示
MacBook fan does not speed up causing overheating despite sensors ok
Hi all,
I havean issue with my Macbook pro retina 13 2014:
despite high CPU usage, the fan spins constantly at 1300 RPM, which causes the CPU temperature raise up to 80C.
All temperature sensors seem to work fine and I can manually adjust fan speed as well as it can be changed by MFC.
Also i tried 3 different fans and the situation doesn't change.
I tried to reset SMC, pram and to reinstall the system (was cooling down CPU manually, don't ask how)
Atm i am using MacFanControl to regulate the speed of the fan, but the issue is still present and causing some discomfort, like i can't install new OS because MFC doesn't run during OS installation and i am afraid of overheating.
Despite all components look good, the system doesn't regulate the speed of the fan.
This happened after i heavily broke my macbook and tried to repair it by replacing its aluminium body, its broken screen assembly and its noisy fan (was a bit bended which caused noise).
It is interesting that after i disconnected touchpad the fan was speeding up normally when CPU temperature was raising. The downside of this was that macbook was constantly throttling , CPU usage was 300% and everything was very slow. I had the same symptoms when camera's cable was damaged.
Can anybody help me with this please?
Macbook photos
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
1 件の回答
最も参考になった回答
I have a Mid 2012 and a mid 2014 Macbook pro. I use a free app called MacsFanControl. It allows me to control the fan and which sensor triggers it.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Dmytro さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 6
今までの合計 556
