メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
モデル番号はA1059もしくはA1099/20、40、60GBハードドライブ/タッチ反応クリックホイール
Hard Drive Failure after Battery replacement
Hello Fellow Techncians
I was wondering if you could help me
I have replaced a battery in a ipod 4th gen with Click wheel, as with all repairs, i very carefully opened it up and removed the hard drive and placed it in a safe place, there was no bumps knocks etc
After replacing the battery and powering it up i get the dreaded folder icon with the exclamation mark
i have tried reseating the hard drive multiple times and i have also tried putting it into disk mode. it gets into disk mode but when i plug it into a PC (i am not using a fire wire cable just a standard ipad 2 cable) it resets and i get the sad face icon
im perplexed as the hard drive was fine before now there is no activity
also when the apple logo comes on there is no back light
Please can you help
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
You will want to carefully inspect the flex connecting the HDD to the logic board. Use this guide.
It may have been damaged or torn when you disconnected the battery. I would also look closely at the connectors on either end. Depending on what is damaged, it may be repairable although it wold likely require a micro-soldering repair. However, if the HDD is at fault, they can only be found "used" and are very expensive.
I recently upgraded a Classic 7th Gen to 256GB flash memory and it was really easy. I have never tried on a 4G but here is a link that may be of interest.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Ali さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 14
今までの合計 402
