Powers on then turns off after a few seconds, what could be the cause?
Vizio M470SV turns on then powers off after a few seconds. What could cause this and what is the fix?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
gregloholt if it truly shuts down, check the power board. Possibly bad caps or MOSFETS. Check for obvious damage. If it does not turn off completely just turns dark it is a backlight issue. Check power board, main board as well as T-Con board. Vizio TV's do have known issues with voltage regulators failing on the main boards. Let us know what you find.
このアンサーは役に立ちましたか?
Amazon Fire Stick remote could be the issue. I replaced AAA batteries in Fire remote and so far problem hasn’t returned.
このアンサーは役に立ちましたか?
過去 24時間: 3
過去 7 日: 5
過去 30 日: 15
今までの合計 34,186
2 件のコメント
Same thing. The only thing I get is vizio on the screen for a half second
Chad French さんによる
Turns on, screen stays dark with no picture, then turns off after a few seconds. Unresolved so far, trying tips.
rweigel さんによる
