メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2013年11月22日に発売されたMicrosoftの第三世代のXbox ゲームコンソールです。
Power not reaching console
The power brick lights orange but when it is then plugged into the console the light goes off and nothing appears to work. I have tried resetting it by disconnecting everything for a period of time but this appears not to work. Is it a fault of the power brick or is it the console?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Do you still have warranty on it? If so I would try contacting them and see if they can do something for it. In the meantime if you have a friend with an xbox one then try using their Power brick and see if it works that will rule out one or the other.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
No warranty as it is approx 2 yrs old. I am in the process of trying to check out the power brick. I tend to think it's the console because the brick does light up. Thank you for your response
さんによる
No worries. Hopefully you can figure it out. Easiest way to figure it out would be the another known good device rather its the power cord or the console. I used to love playing on my Xbox 360 then it got a ring on it and I just switched all together to playstation. Best of luck to you!
さんによる
コメントを追加
回答を追加する
David さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 6
今までの合計 112
