メインコンテンツにスキップ
A 5.9'' Full HD screen 1080p, 1.7GHz quad-core CPUs and 3300 mAh Battery
18回答 すべてを表示
Repair Sim-Card Slot of HTC One Max
Hello,
how can I change the Sim-Card Slot? How do I remove it from the Motherboard? Is there any screw?
Here a photo of the part:
https://ae01.alicdn.com/kf/HTB1T9X1KFXXX...
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Thorsten Klein , No screws, this is really not a repair for the inexperienced because the Sim-Card reader for your device is soldered to the mother board and the heat generated could cause further damage if not very careful. If you do want to give it a shot, I will post a link to a tear down guide to get you inside the tablet to check the Sim-Card reader and will also post a link showing what is involved in changing a Sim-Card reader attached to the board (not your exact model but gives you an idea). If not up to doing repair pop into a good local cell/computer repair shop and have them take a look and estimate repair. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
HTC One Max Motherboard Replacement
https://www.youtube.com/watch?v=3fw-gf9t...
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
To change sim card slot is a very difficult step but after reading and also watching this video, one could take great help to remove sim card from your HTC One Max <a Smartphone and get rid off from faulty one.
www.phoneadept.com.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Thorsten Klein さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 966
