How do I remove the dome light
How do I remove the dome light fixture so I can replace the headliner material.
This fixture does not have any screws....
B Brower, I believe it's just held in by tabs around the edge. pry on the plastic tabs and pull down gently until all the tabs are out. As long as your are careful with it you shouldn't have any problems. Check the link below as it may be helpful. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 5
今までの合計 1,656
