メインコンテンツにスキップ
特別なタスクをこなす農作業用や建築現場用の乗用車。これらは走行スピードが遅く、大規模な作業をこなします。
83回答 すべてを表示
Why is the tiller not spinning when the PTO shaft is?
It seams to be the part between the PTO shaft coming from the tractor and the gearbox on the tiller. From the looks of the diagram I found online it looks like the friction clutch assembly is just spinning freely around the shaft that goes into the gearbox on the tiller. Not sure what could be the problem or what part I may need to fix it.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
4 件のコメント
@rogershepherd post the diagram and a few images on what you are working on with your question. Use this guide iFixitでの質問に画像を追加する方法 for that. we'll need to know what tractor and what tiller. Right now it sounds like the PTO out is okay, just nothing happening on the tiller end. Check for any shear pins and the drive.
さんによる
Usually its just the sheer pin designed to take the torque of a sudden stop in the tiller (like hitting a large rock) and not breaking parts in the tractor or tiller by having the small sheer pin sheering in half...
さんによる
Yes .,. This is what I’m thinking is going on with my county line ... thank you ...stay safe and well ... take care brother
さんによる
さんによる
コメントを追加
2件の回答
最も参考になった回答
without seeing it in person or a good video, i sounds like the clutch is bad, there should be fiber plates in between ,they can wear if the pack is allowed to loosten. Sometimes you can tighten the bolts that go through the springs,(usually about 6 ) tighten each bolt an the same amount of turns to keep pressure even.
Another way you can check to be sure it is the clutch pack (because it could be the drive chain jumped off), raise and block up the tiller so it cannot fall, shut tractor completely off and remove key, engage pto with engine off, now reach under the tiller and rotate the blades, if the one side of clutch pack rotates but does not turn the shaft half, it is the clutch. BE CAREFULL! DONT PINCH OR CRUSH YOURSELF. BE SURE TRACTOR IS OFF. AND BE SURE IMPLIMENT CANNOT FALL ON YOU. NEVER WORK ON PTO EQUIPMENT WHILE RUNNING OR IF TRACTOR CAN ACCIDENTALLY START.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
look up slip clutch adjustments,
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Roger Shepherd さん、ありがとうございました!
統計データ:
過去 24時間: 11
過去 7 日: 43
過去 30 日: 187
今までの合計 8,601
