Why does it stop on starting windows for even a day?
i have a dell lat E6500, after putting in another hard disk, it opens but it eventually stops on starting windows i dont know why and what to do.
@mm2 , matutu moses , Just a thought: If the hard drive has not worked since you put it in and you do hear it running, perhaps the OS did not install properly and you may want to try a reinstalling the OS. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 82
3 件のコメント
Hi,
What OS is installed?
Does it start OK in 'safe mode'?
jayeff さんによる
Are you saying you have 2 hard drives currently in the same laptop?
S W さんによる
More details, Please. Did you replace or add a hard drive. Is the hard drive identified in BIOS (hit F2 on start up when you seen the Dell logo)? What version Operating System are you using, is it Home, Professional, 32 bit or 64 bit? Are there any error messages?
DrGlowire さんによる
