Were is the camshaft position sensor located?
Hello I have a 2010 Toyota Camry 3.5 liter motor. I would like to know were it is located?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
There are 4 Cam pos. sen. on the 3.5 , 2 on each bank, for their locations see the attached link.
Crankshaft position sensors are all located in about the same position on all cars. They all are on the end of the crankshaft usually behind the harmonic balancer on the front of the motor. They are positioned to get as close to the crankshaft as possible as they need to be able to almost touch the spinning crankshaft to work . Hope this helps
このアンサーは役に立ちましたか?
sorry misaddress that hes looking for a cam sensor not the crank sensor
Here is a thread on how to replace it with diagrams on where it is located.
このアンサーは役に立ちましたか?
過去 24時間: 3
過去 7 日: 35
過去 30 日: 148
今までの合計 18,484
1件のコメント
I have a 1999 Toyota avalon 3.0 and am also looking for sensor.
Judy Caldwell さんによる
