vechicle too low sign comes on
snow1544 , You have a air suspension fault. Have scanned for codes and checked for fault by a good technician. If you can hear the compressor run and the vehicle will not lift then there's an obvious leak, possibly air line, air bag, or maybe leaking O-rings at the bag solenoids. It could also be caused by an electronic glitch; ride height sensor, etc.
May get some info. from links below. Good luck.
http://www.jaguarforums.com/forum/xj-xj6...
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 5
過去 30 日: 15
今までの合計 228
1件のコメント
Why is it doing that?
Conor Bailey さんによる
