micro sd card slot not workin
I recently changed my processor fan,Since then my micro sd card slot has stopped working.i tried installing the factory shipped drivers.it is also not showing in the device manager.my current os version is windows 10.
Shoaib Sayyad, Maybe try a system restore, back to when the card reader was working. Check if the card reader is disabled in BIOS settings. At the first screen after restart, look for a key to press for Bios or Settings and verify that the card reader has not been disabled in the Bios settings. The links below may also help with your issue. Good luck.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 13
今までの合計 609
