メインコンテンツにスキップ
The Pontiac Grand Am is a mid-size size (and later compact) car produced by Pontiac. The 1999-2005 generation is the final generation of the Pontiac Grand Am.
fix a radiator leak with JB Weld?
Can I fix a radiator leak with JB Weld ????
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Reggie Island, What type of leak are you trying to fix a core/tube leak, plastic tank crack, tank to core seam leak, where is the leak?
さんによる
will it fix a gas leak
さんによる
コメントを追加
2件の回答
最も参考になった回答
Reggie Island, JB weld possibly a temporary fix. See the attached links for better ways(permanent) fix of aluminum core tube leak or cracked plastic tank. You can also check with local auto recycler for rad replacement as they sell usually for fraction of the price of new. Good luck.
I hope this helped you out, if so let me know by pressing the helpful button
https://www.youtube.com/watch?v=ehMJPQ9S...
https://www.youtube.com/watch?v=nblbiu_v...
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Reggie Island no you cannot. JB Weld, no matter how good it is, will not withstand the coolant, the heat and the pressure inside your radiator. Fix your radiator properly by either having it soldered or replaced, depending on the damage.
このアンサーは役に立ちましたか?
スコア 0
7 件のコメント:
@oldturkey03 Its not often or if ever I disagree with you but in this case I am . if the car has a plastic tank with aluminum veins then yes it can be fixed with JB weld depending on the area to be fixed Idf its the seams on the side of the tank you can remove the side straps and reseal the tank and JB weld works well here as long as the side straps are crimped back in place properly. if the leak is in the veins than your right it cant be I think @lpfaff1 was thinking the same way when he asked what exactly was leaking
さんによる
@jimfixer nothing wrong with some disagreements. I will always welcome those :-)
さんによる
You can definitely fix a radiator leak with JB Weld. Especially since they make a product called "Radiator Weld" LMAO
さんによる
no...jb weld will not fix a radiator. I'll explain why..it will temporarily fix it for a short time but pressure will build up and find a weak spot blowing out the repair or by making the crack bigger..I know from multiple experiences and I'm actually doing it right now
さんによる
Flex Seal should do the job! lol. I have a very small leak on the top of a plastic radiator, going to try the JB weld if it dosen't work. I've only spent a couple dollars and a half hour if not Polyvance has a tested trued product
https://www.polyvance.com/radiator.php
さんによる
2件以上のコメントを表示
コメントを追加
回答を追加する
Reggie Island さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 15
過去 30 日: 35
今までの合計 21,214
