Repair guides and support for top and front loading Whirlpool brand washers.
Todd Blaubach @ncitjb3
評価: 1
投稿日: 2017年3月13日
After the drum had been filling with water when it was off and put the CLR in the water hose. Now the machine won't run due to an error code of FH?
この質問は役に立ちましたか?
@ncitjb3 ,Todd, Did you turn your water supply back on to fill machine.
L Pfaff さんによる2017年3月13日
Conor Bailey @thethirdtwin
評価: 8.1千
Tech Haus
13
10
FH seems to indicate that the problem is with the amount of water in the machine is not the amount the machine expected.
This link explains in some detail the issue and some possible fixes:
https://www.repairclinic.com/RepairHelp/...
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 17
今までの合計 3,062
1件のコメント
L Pfaff さんによる
