メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Sony Computer Entertainmentによって製造されたPS4と通称で知られるテレビゲーム用コンソールです。2013年2月20日に製品の発表、2013年11月15日に発売されました。
How to fix the Fan header
I was disassembling my ps4 and got down to the fan header. I thought that you had to pull the cord horizontally and did that without knowing that I had to do it vertically. So then I accidentally broke the fan header but was able to repair it, temporarily, with the ps4 shutting down most of the time due to overheating. I want to know if there is a permanent solution to fix the fan header, so then I don't have to play with it all the time to keep the fan running.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
2 件のコメント
Can you post pics
さんによる
this will help with posting a picture
iFixitでの質問に画像を追加する方法
さんによる
コメントを追加
3件の回答
ベストアンサー
It sounds like you must be talking about the fan connector on the motherboard. If that's the case then you have several options:
1) Solder the fan wires directly to the correct pins on the motherboard
2) Replace the connector...if the connector on the motherboard itself is broken then you would have to probably get a connector from a junk motherboard. If it's the connector on the fan side you could just replace the fan.
3) You could purchase a new motherboard...this option is obviously not the best since it's so expensive but it is an option.
I hope this helps. Good luck!
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Hey Steve, I have been trying to buy a new set of fan headers (10 pieces) from Ali Express but they sent the plugs from the fan side NOT the sockets I thought I ordered, now they have blacklisted me from buying anything because I returned the wrong items! Where do you suggest I can source the correct item(s) as I am in Australia and it is hard to get parts for consoles? Looking forward to help.
さんによる
コメントを追加
This happened to me but it was on the fan side. I just discarded the plastic and connected the cables directly to the mother board without having to solder. PS4 1100 series
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
How did you manage to do this?
さんによる
コメントを追加
I did it with a needle it lifted it and slides out after
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Astrowings230 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 31
今までの合計 6,090
