Why is my trio stealth 10 screen display "@9 dual core"
When I turn on my trio stealth 10 my screen displays @9 Dual core. Can someone help me with this?
You need to perform a factory data reset. I did this by going into recovery mode (Power button and volume down, release the power button after the logo appears, release the volume button after about 5 seconds). Choose wipe data/factory reset and then choose wipe cache (maybe optional) also. Please remember this will delete all data from the tablet, so if you don't have a backup, you will lose your data.
Choose reboot after this and it should boot up normally (takes longer than usual). This worked for me
このアンサーは役に立ちましたか?
I have the same trouble with mine , i have tried to do the factory reset but it is now stuck on wiping data/formatting data in the rest. it wont actually reset . I have tried this multiple times ,i have wiped both the cache and media (they say wipe is complete on both) but the data wipe will not finish . is there anything that i can do ,I love this tablet and cant afford a new one . Any help would be AWESOME!! thanks
Unfortunately, if the wipe itself is not completing, it's probably hitting a bad part of your memory or something hardware related. Just my opinion though. Can you try removing your memory card if you have one in there, before trying a wipe next time?
I followed the directions and it went back to @9 dual core. What else can I do to get this @9 dual core off my screen?
I had to try this option 3 or 4 times. I was about to toss the tablet, thought I would try it one more time. Wah-la - it worked!
過去 24時間: 4
過去 7 日: 7
過去 30 日: 10
今までの合計 2,399
Have you tried doing anything to it before you posted a question?
ULEES さんによる
No because I can't get it off @9 Dual Core
Sandra Castle さんによる
