メインコンテンツにスキップ
Repair information for the Garmin Vivoactive HR smartwatch. Released in February of 2016. Model number: 010-01605-03.
21回答 すべてを表示
display broken / need replacement display
Hey everyone,
unfortunatly I crashed the display of my Gamin Vivoactive HR.
I called Garmin for a replacement and they told me its about 150€.
Is there any other possibility to replace the display by my own?
Buy the display seperatly anywhere ?
I am thankful for every help
Best regards,
Andreas
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 5
1件のコメント
Hey everyone,
Best regards,
Cesare
さんによる
コメントを追加
5件の回答
最も参考になった回答
Hi Andreas,
I have a used display. Are you still interrested?
このアンサーは役に立ちましたか?
スコア 2
7 件のコメント:
Is the used display still available?
さんによる
Yes is still available
さんによる
Hey there, I am also interrested. Could you please tell me if the Display is still available? You can also directly contact me via gerrit.puddig "@" conjin.de. thanks
さんによる
Hi.
May I know ifthe display still available?
さんによる
Leonidos didn't answer me. See my Question above...
さんによる
2件以上のコメントを表示
コメントを追加
I had to open my Vivoactive HR because it wad died, what I saw it was water inside device :(
Now I know that it is no super easy way to open this Garmin.
1st. you have to unglued plastic part where buttons sits
2nd. using this hole (buttons whole) you should gently push screen using something like screw
  • be careful with electric tapes (there are few) it is easy to broken (tear) using only a little force
  • there is only 1 screw on button board
Maybe my photos will help anybody to repair this Garmin.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
So I have a vivoactive hr and yes a crack screen n unresponsive to touch too. Opened it up( direct from screen) and it wasn’t that hard too, but I really hope they start selling the screen so maybe one day I can replace it.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
How did you get the screen off? Trying to get it off without completely destroying the unit.
さんによる
It’s being hold down by adhesive tape so use heat
さんによる
コメントを追加
You can buy a display there :
https://www.smitacn.com/lcd-screen-for-g...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Good to know for future, but in not much more you can buy used but working device :)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Andreas さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 11
今までの合計 4,666
