メインコンテンツにスキップ
2012年半ばモデル、A1278/2.5 GHz i5または2.9 GHz i7プロセッサー。
1624回答 すべてを表示
Broken iSight cable (pulled out of connector)
I pulled the wires out of the iSight camera cable at the logic board the connector is still in place I just pulled the cable out of the connector. How do I fix that?
MacBook Pro (mid-2012) 13"
Thank you
Update (03/09/2017)
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
2 件のコメント
Could you please send photo
さんによる
Uploading a picture
さんによる
コメントを追加
4件の回答
ベストアンサー
you need to replace the entire webcam with cable, which is difficult because you need to take of the entire display assembly and then separate the glass from the rest of the toplid.
このアンサーは役に立ちましたか?
スコア 1
7 件のコメント:
Ya I'm good on all that I don't need the camera that bad
さんによる
You might want to use tweezers to push the broken connector out of the socket though. On some years it causes an issue with sensors, so the fan spins high speed
さんによる
issues with fans are only when temp sensors are disconnected.
さんによる
Fan is good I monitor it also with temperature of the CPU
さんによる
On a good note it's only reaching 63 degrees C under heavy load.
さんによる
2件以上のコメントを表示
コメントを追加
What are the effect of a broken isight camera cable on macbook 2012 pro …apart from camera….
I need answers thats based on sensor, relation of display back light
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
i also wanna know.. because my computer suddenly cant find the wifi..
さんによる
same situation here. Tore out the socket and was wondering if I really need to fix it.
さんによる
コメントを追加
I have been using it without the connector for the past 1 year. All I notice for the difference is no more camera and mic is not working for me. I'm wondering if the mic has to do with the isight port or my mic just coincidence to breakdown at the same time. The rest like fan and sensors was not affected at all. I'm using a A1278 MBP.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Hi Guys i have the same problem on macbook pro 13 late 2011 and I cant find a way to remove the connector. Any ideas please because thats must be the reason that my fan works like crazy. Appreciated any help!!
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
That 's so hard to get it out. I using the cuter . Look at the side of socket. You found the space between the plug. So using the blade insert between that and Try to push the socket out. Please try the both side left and right. Until the socket going out.
さんによる
コメントを追加
回答を追加する
Collin.nesbitt@gmail.com さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 10
過去 30 日: 37
今までの合計 7,270
