メインコンテンツにスキップ
Released Q2 2009, identified on serial number sticker as 'nuvi 1200'
3回答 すべてを表示
Device continually reboots during map loading stage
When starting the GPS the progress bar displays, but once it gets to the 'Loading maps' stage it reboots and starts the cycle over again.
I tried doing a factory reset (by booting while touching the bottom right of the screen). When the screen asked if I wanted to do a factory reset the 'Yes' and 'No' buttons were unresponsive.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
3件の回答
1. Try connecting to a PC!If successful,
2. Connect to computer, & do a forced re-install of the map.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Next thing I would try would be to crack open the case (Provided there is no warranty), seperate all of the parts, ensuring that all cable , - or plug connections are seperated, get some aluminium foil, & foam rubber, press the rear of the board, - boards onto the al foil. This completly discharges everything, - allowing for a fresh re-boot. microscopically check for any corrosion, and clean off if any found.
Re-assemble, plugging in the battery last. And then re-boot. Remember, - use fabric gloves, and keep yourself earthed. I have had more success with this aproach than failures.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Call up garmin support and have them walk you through reflashing the firmware through the boot block method. This will reflash the device's firmware to the latest version and may fix the issue where it reboots during the loading maps.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Zachary Landau さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 4,761
